Hi guys
my name is Xavier, i'am french
(thank's google) and i live Saintes
(17 charentes maritimes almost La Rochelle for connoisseurs)
I have a MR2 turbo US rev 1.
It's the only model with turbo and LHD)
I have
(or rather a friend) many modif.
The 3sgte gen 2 was remplaced by 3sgte gen3, sway bar, hub, bushes and brake come from a rev2.
-gasket hks 1,2 mm
-cylinder head bolts ARP
-rod bolts ARP
-rod eagle
-forged piston cp 86
-crankshaft and connecting rod bearing ACL
-injectors SARD 800cc
-clutch exedy stage 2
-down pipe berk technology
-exhaust mongoose
-Apexi power fc
+ comander+ boost controler
-oil pressure and oil temperature guauge
-gearbox gen3 avec lsd
-rims rota torque en 7x17 with tire toyo T1R
(almost dead^^)
-blow off dump valve Blitz
-damper koni
-braking rev2 with disc front and pads front and rear ebc yellow stuff, rear disc oem
-turbo timer blitz
-front spoiler
rev2
-corner rev3
-rear light
rev3
-home made ic with 76 piping
alu,water cooler alu
I have lot of option.
cruise control, air conditioning.
(I can not post photo!!!!)
