[Mk2] [Turbo] "E" markings on Turbo Rev4+, please help
smoke
Post by smoke »
Hi there,
I got my NA rev 4 imported in Belgium and now I'm playing with the conversion of the headlights with EU spec unit.
I'd like to know if also the Turbos Rev 4+ have all the glasses and the lights with the "E" markings (as in mine, also the roof ones!). :-k
If someone is so patient, I'll ask also of the harnesses. :D
I'm planning to buy also a Tubby in the future and I think this is mandatory staff... :cry:
Marf
Re: [Mk2] [Turbo] "E" markings on Turbo Rev4+, please help
Post by Marf »
Pretty sure my Rev3 Turbo has e-marks. If not then just get yourself some lights from a locally delivered car of the same age.
smoke
Post by smoke »
Thanks Marf.
Actually you are right, headlights are not a big problem.
Windscreen, windows and all the glasses may be another oreder of expense... :oops:
toxo
Post by toxo »
They should all be E marked. I know the wingmirrors, rear lights and sidelights are all E marked but I couldn't tell you about the headlights because I run aftermarket ones.
Marf
Post by Marf »
I'll check my headlights at lunchtime, they're stock.
Marf
Post by Marf »
Nope, no e-marking on the lenses.
Would be worth getting someone with a UK car to check too.
smoke
Post by smoke »
Thanks,
I've got a Rev 4 UK and I've got E marks all over...
Starting from Rev 4 tough...
smoke
Post by smoke »
Thanks,
smoke
Post by smoke »
toxo wrote:They should all be E marked. I know the wingmirrors, rear lights and sidelights are all E marked but I couldn't tell you about the headlights because I run aftermarket ones.
Thanks,
just a confirm:
are you talking of Tubby Rev 3, aren't you?
toxo
Post by toxo »
Yes. It's not the actual glass on the wingmirrors that's marked, it's the mirror units themselves. I've got a photo of the back of the mirror glass somewhere, I'll see if I can dig it out.
smoke
Post by smoke »
It's ok, it is the same on mine.
I thought they started to mark all around on Rev 4.
I'm happy!!! :D
It seems I can import them :D
Tubby tubby, I'm coming...
Already with double fog lights, isn't it?
The front lights have to be changed anyway in order to drive on the other side...
Ren0W
Post by Ren0W »
Mijn turbo is ook te koop... is mss een stukje makkelijker voor je met ophalen/importeren ?
smoke
Post by smoke »
Actually all the turbos are without the Certificate of Conformity, so it is a big mess anyway...
(kind of SVA procedure...) ](*,)
