Rear camber adjustment
Can the rear wheel camber be adjusted on the mk3?
Re: Rear camber adjustment
From memory back when we ran an IMOC day at Elite, they fixed the rear camber on a Mk3 with some crash bolts to sort the handling.![](./images/smilies/spacer.gif)
Correct.
Rear camber is not adjustable
"out of the box".
You have to add additional bolts that will do it for you.![](./images/smilies/spacer.gif)
