Petrol filler neck missing??
Rev5_GTS_Nick
Post by Rev5_GTS_Nick »
I went to fill up the car and as i put the nozzle in the filler neck and it felt all loose and had a look and the nozzle restrictor is now missing?
I cant understand where it could have gone?
Has anyone experienced this? Can i get a replacement.
djpkins
Re: Petrol filler neck missing??
Post by djpkins »
I can sort you with what you need...but you'll have to put up a pic so I can see which bit :thumleft:
Rev5_GTS_Nick
Thanks, its the insert that goes into the filler neck that reduces the hole diameter.
Not sure which part it is either.
hope that makes sense.
Rogue
Post by Rogue »
The restrictor would have been fitted when it was imported to the UK - it was a requirement of the SVA test. It's to stop you putting diesel in by mistake, or you can use common sense instead. :thumleft:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0191784531
