[Mk2] [Generic] MR2 Tubby Specialist near Birmingham? Clutch seems to be shot :(
alan-2-turbo
Post by alan-2-turbo »
Hi guys,
I'm having a few issues with the 2.
Firstly i run a blitz sbc boost controller. When the car boosts as i go from negative into boost, the led display screen on the sbc disappears and my cd player cuts out? then comes back on when i back off the accelerator.
It feels like its running half the power.
Secondly the clutch is slipping under load at high revs, anywhere recommended to get these problems looked at?
Cheers Al :|
ashley
Re: [Mk2] [Generic] MR2 Tubby Specialist near Birmingham? Clutch seems to be shot :(
Post by ashley »
Rogue?
alan-2-turbo
Cheers fella only 40 miles away, so maybe possible before the clutch implodes.
What sort of price for a clutch change any ideas?
ashley
Post by ashley »
Give Matt a call: 01926 810104, he'll sort you out :thumleft:
alan-2-turbo
cheers fella :)
SonicSW20
Post by SonicSW20 »
MrTwos in Willenhall should be pretty close to you!
woz_106
Post by woz_106 »
Gazza_DJ wrote:MrTwos in Willenhall should be pretty close to you!
+1 for Nathan at mrtwos top guy always eager to help.
alanmr2turbo
Post by alanmr2turbo »
+1
Stay well clear of Rogue unless you want to pay over the odds
alan-2-turbo
booked in with Nathan at mrtwos, thanks for advice fellas.
Now anyone know of a decent clutch going? Road use for maybe 1bar of boost tops?
Cheers again.
cvega666
Post by cvega666 »
for that kind of power standard clutch kit will do you just fine....
alan-2-turbo
Are the exedy ones for 140 quid on ebay good for the job?
woz_106
Post by woz_106 »
for that sort of boost mate, as said the standard clutch can cope with that easily.
