im looking to do a fresh head as a spare and not sure what valve springs to go with, I have a fresh rev3 head ported and polished with ferrera 1mm oversize valves piper cams the rpm limit is 8500rpm any sugestions welcome
Piper?
That's what I went with using rev 3 head and Piper TOYSGBP285's.
Not got OS valves though, but do expect to rev upto about 8 - 8.5k
I went for single springs as dual requires some more head work I believe.
January 2014
May 2015
Mike N wrote:You should consult the cam manufacturer for the correct spring poundage rate for that specific cam and use rev 3 followers.
As above.
Minimum spring rate to control the valve under its operating conditions is whats required.
Excessive rates means valvetrain wear and parasitic losses ( drag) which lowers engine power.
I've bought a set of uprated valve springs new from brian crower which are the same as the HKS ones but cheaper. IIRC i paid £160 for them.
I'm the same, rebuilding the head with 1mm over sized valves and HKS 264 cams and cam gears. Port and gask flowed head.
bobhatton wrote:I hope you are all opening up the throats and cutting back the valve seats when you fit the bigger valves.
+1
And dont do the costly mistake momentum motorsport did.
6 of the intake valves were leaking and 2 exhaust valves were also leaking. Seems they just took them out of the box and just grinded them into the head
I thought that most spring upgrades were just 'snappier' springs, rather than the physical dimensions being different?! I'm more than likely wrong though.
I haven't had my head modded to take my piper single springs, but was advised (by Piper) that if I were to use the double springs, I'd have no choice.
January 2014
May 2015
[quote="Shmed"]Ring Piper, they're very helpful on the phone, and their springs aren't too expensive either.[/quote
yes i will do in the morning see what they suggest
ATS do a nice set of uprated springs, i have a set in mine -not tested them yet tho as the car is still in bits however i know ats and co are using them with good results out in the USA. The springs are about 10mm taller than the stock rev3 springs and do feel a lot stiffer if you press on them.
Btw, be careful what oversize valves you use! I hear of a lot of people having serious issues with ferra 6000 series due to a whole batch leaving the factory without heat treatment!
