Oil sensor locations, fittings etc
Shmed
Re: Oil sensor locations, fittings etc
Post by Shmed »
Bought everything I need now cheers Steve. Got some gauges from an Elise store, they look kinda like my innovate MTX, which is a bonus, and they weren't over expensive either. Bought the braided t piece from demon tweaks for £20.
Thought I'd get in before the thread gets locked :)
January 2014
May 2015
Still in the garage...
greeny
Post by greeny »
Steve Horrocks wrote:
Marf wrote:If the stock sensor is anything like the sensors found on other Jap motors, it'll trigger the warning light at around 0.5 bar.
With that in mind the oil pressure warning light is more of a "you're engine is xxxxx light."
So yeah, no loss in losing it so long as you keep an eye on your oil pressure gauge.
Iirc, I think the light comes on at around 3-4psi!! But there's every chance that info was wrong!!
I've also got a braided T-piece that I need to get rid of as well. PM if anyone is interested. Oh, and an oil pressure sensor & gauge (nothing fancy, but kept an eye on things for me!!)
7psi IIRC Steve.
Also if anyone's fitting a pressure sensor/sendor in the oem location, i'd definately run a braided/flexible line and mount it on the chassis somewhere, as in time it'l vibrate/rattle the sensor to an early death.
Steve Horrocks
Post by Steve Horrocks »
ahh, cool, so it is 0.5bar then.
I had my sensor tied to my boost pipe running next to the stock location so it was vibration free.
Gone, but never forgotten
Now with a mk1.5 & a NHB EP3
djpkins
Post by djpkins »
I have just taken a HKS oil pressure sensor from a rev 3 engine that I'm working on...it was attached via a braided line and screwed into block underneath the oil filter region...is this a stock location? can't post a pic cos I've done my back in and can't spin the engine around.
Shmed
Post by Shmed »
No mate, the stock location for the pressure switch is on the head, on the same face as the dizzy.
January 2014
May 2015
Shmed
Post by Shmed »
Have a look on this pic (I posted it elsewhere and noticed the stock oil pressure sensor staring me in the face)
The sensor sticking out above the water outlet is the oil pressure sensor. :thumleft:
January 2014
May 2015
djpkins
Post by djpkins »
I know that :thumleft: ...lol...but this one I have taken off was hidden right at the bottom of the block, and I was wondering if it's been drilled and tapped out or whether it's been put in another hole meant for something else...sorry to hijack your thread old mate...but if a better location is possible then maybe you could use that, your on a rev2 block though arn't you...
Shmed
Post by Shmed »
Yep, I'm rev2 block
Sorry, I didn't mean to try and teach you to suck eggs :oops:
January 2014
May 2015
djpkins
Post by djpkins »
not my engine...but could be here...
Shmed
Post by Shmed »
Is that where the oil level sensor goes? Mine doesn't have one, so I don't know, but it is listed in the BGB.
January 2014
May 2015
djpkins
Post by djpkins »
Right...is it a rev 3 onwards thing then...sorry man, though I'd turned something up.
Shmed
Post by Shmed »
Don't know mate, I only know things that people have corrected me on :lol:
January 2014
May 2015
toxo
Post by toxo »
Oil level sensor on JDM N/As IIRC. Although perhaps on UK cars too, can't remember.
Shmed
Post by Shmed »
Where is the best place for an EGT probe? I know in an ideal world I'd have one on each exhaust port, but I haven't got, and I won't be getting four probes/gauges.
I was planning to go for the bung at the bottom of the downpipe, but the pic suggests putting it at the meeting point of the four exhaust ports in the manifold.
January 2014
May 2015
Marf
Post by Marf »
Best place for it is pre-turbo, you'll get the most accurate measurement there. I had mine in the exhaust manifold on my old Charade Turbo.
Putting it post turbo will give you less accurate readings as the exhaust gas cools due to transferring energy into spinning the turbine.
Shmed
Post by Shmed »
Yeah, that's what I thought. I read that the egt can drop 200degrees across the turbo.
January 2014
May 2015
Marf
Post by Marf »
Yep sure can. You want to know the temperature coming out of the cylinders.
Shmed
Post by Shmed »
So either tap into the stock manifold, or into my adapter plate (from the blue forum guy...)?
January 2014
May 2015
Marf
Post by Marf »
Tap it into either. You'll want a threaded tap
Shmed
Post by Shmed »
Aren't all taps threaded? :-s
January 2014
May 2015
