You need to remove the door card and inspect the loom for broken wires, tracing back from the switch in question.
.are all the 3 plugs
, that lead from the door to the drivers footwell, in place?
It's more than likely the switch wires though, as power is getting to the window.
.just think of the switch wire(s) as 1 big loop with the switch connecting/disconnecting them to make/break the circuit.
Also look at the connectors that the switch block plugs into, my t-bar leaks and drips right onto that switch, so there may be some corrosion in that area.
Worst case scenario.
.you will need to run 2 new wires from the switch to the footwell and just snip/twist onto the loom
.near the connectors.
