[Mk2] [Turbo] RE: Brake caliper grease.
costelg
Post by costelg »
OK....
Am doing a rebuild of the brakes on the 2.
My only question is what grease do I use on the brake:
sliding pins??
piston??
and squel shims??
I have done some research and all I got is contradictions : (
some say use copper grease, castrol LM, silicone based, plumbers silicone, lithium based grease (Red and white) and flourene based grease.
Surely there is some definate answer to this as brakes are vital!!!
I dont think putting copper grease on piston seals is advisable but there are people out there!!
All replys welcome...
George
94 GTS
dansREV2turbo
Re: [Mk2] [Turbo] RE: Brake caliper grease.
Post by dansREV2turbo »
lithium grease for the sliders
ceratec paste for the pads/shims (this better than copper grease if you have abs)
pistons dont need greasing.
costelg
Post by costelg »
Will any lithium grease do?
Any recomendations?
I was looking at:
http://www.crcindustries.com/hd/content ... =05359&S=N
