[Mk2] [Turbo] Reverse lights inop
nicholasmitchellmr2
Post by nicholasmitchellmr2 »
Hi to everyone,
i have a rev2 turbo and the reverse lights are not working.
it has the standard lights fitted, im not getting any voltage at either reverse light bulbs when in reverse.
i have also checked voltage supply to the reverse switch which is only 3volts.
i have also shorted the reverse light switch with a fused wire to rule out the switch and the lights still do not work.
does anyone know what sort of voltage i should see at the switch and also is there a decent wiring diagram out there?
many thanks in advance,
nick :mrgreen:
pbmr2
Re: [Mk2] [Turbo] Reverse lights inop
Post by pbmr2 »
ecu-ig fuse.. in the engine bay.
there are all the manuals you need HERE
Return to “Electrical”
