[Mk2] [Turbo] single wiper conversion
Has anyone ever fitted a storm single wiper conversion?I am having a bit of trouble fitting mine and could do with some help.
Re: [Mk2] [Turbo] single wiper conversion
I have made my own single wiper by following this guide http://www.jekylhyderacing.com/wiper.htm and since changed and fitted a Storm kit which I have just transferred from my rev1 to the rev3.
What problems are you having
Can you tell me how you remove the triangular spindles from the original arms to put on the new one.My no is 07894076134 if it is easier to explain over the phone,many thanks.madbasshunter wrote:I have made my own single wiper by following this guide http://www.jekylhyderacing.com/wiper.htm and since changed and fitted a Storm kit which I have just transferred from my rev1 to the rev3.
What problems are you having?
There is a circlip on the spindle which holds it in to the triangle which you need to force off IIRC
madbasshunter
- how comes you changed from the DIY conversion to the storm kit?
RyanRs wrote:madbasshunter- how comes you changed from the DIY conversion to the storm kit?
I made a mistake to be honest I bought the storm kit as I wanted to change the park position so the wiper parks in the middle of the screen then realised that its done by moving the position the linkage fits on the motor Doh so to be honest I would have kept the diy kit but I had already let someone else have it.
Sorted,thanks for help folks.
