I have found this needs to be done at least 4 times a year with something that will bloat the rubber to as close to its original shape as possible and try and keep it soft and plyable.
When doing this, its best to have a garage so that you can leave the car in there for a few hours with the Tbars off and the doors open to give the rubber time to get fully plumped out.
Its worth doing this just before the first frosts of winter as well otherwise your TBar will make a horrible creaking sound when driving as it flexes.
There used to be a superb product for this but they stopped making it a few years ago.
If anyone uses a waterless cleaner on their car, which are ok on rubbers, dont use it on the Tbar rubber as the surface becomes so slick water will get by the door window.
If you end up buying new Tbar rubbers, I have heard they are not the easiest thing to fit correctly so suggest getting it done by someone thats done it before.
