cheers
aw11rally wrote:Late spec 4A-GZE would be easiest labour wise, no need to change mounts or box, just the wiring.Finding one would be the issue.
AE101 with DLI and forged bottom end as standard is 150/160bhp out of the box(corolla) and with a lot more torque than the 20v.
190bhp max with mods before the SC12 gets things too hot.
V6 or 3S-GTE give more grunt but with more hours/pounds.
cartledge_uk wrote:aw11rally wrote:Late spec 4A-GZE would be easiest labour wise, no need to change mounts or box, just the wiring.Finding one would be the issue.
Funny you should say that, I have one in the garage i'm tempted to sell![]()
smokeejoe wrote:pm sent
Ok next stupid questions what other parts would be required for the swop? do i need a GZE loom? ECU? Driveshafts? Do i need to change the fuel pump? Any advice on parts required would be great cheers guys.
smokeejoe wrote:Thanks for the advice phil had thought about getting a complete donour car but unfortunatly just dont have the space.Thanks for the offer will be a great help when i inevitably get stuck.
Is the na gear box strong enough to deal with the extra power? or would i be better off with an SC box?
does the na box bolt straight up to the GZE?
Will a mk2 pump be sufficient to fuel the GZE
(i read that they fit straight into the carrier from a mk1??) or will i still need an after market regulator?
Is there a regulator you would recomended?
Really sorry for all the questions
