1995 Mr2 Rev3 uk Converted To rev3 turbo
Donk
Post by Donk »
This is my rev3 Mr2 n/a GT T-Bar which has been converted to a rev 3 turbo.
I bought the car in march this year as a standard low mileage full black leather rev3 n/a for nearly £2000 and since then it has been converted to a rev3 turbo using a complete rear clip, loom and ecu from a 97000 km rev3 gt turbo. the overall condition of the car is in good condition but does have the odd mark but it is a 15 year old car. viewing is welcome. the car pulls like a train and runs well with no smoke or misfires always run on super unleaded . it is running around 260bhp on standard boost.
Spec
Rev3 turbo engine (with the aircon pump removed)
Rev3 turbo lsd gearbox
Xs power s/s twin exit exhaust
Uprated intercooler
Magnecor leads
Air impulse 2 induction kit
Ohlins adjustable shocks
Trd lowering Springs
Cusco front and rear strut braces
Tein pillow ball front tension rods
walbro 255l/h fuel pump
16" staggered yokahama advan sa3 split rims
Exedy racing clutch and lightened flywheel only done about a 1000 miles
Thats the good bits now for the bad
since the conversion was done about a month ago their are a couple things tha still need sorting which i havent got time to sort out
The speedo does not work (the speedo wire takes a different route on the turbo import to the uk n/a so the wires just need to be found and joined )
The low oil warning light is on (the bulb needs taking out as the turbo rev3 doesnt have a sensor for a low warning light )
the abs light is on ( it needs a power feed to the abs ecu as the wire takes a different route on the turbo loom)
the rear fog light warning light comes on the dash when you brake (the turbo loom has an extra earth which needs finding and cutting )
the front tyres need changing as they are a bit perished
one of the front wheels has some of the nuts and botls missing front the split rims
the tracking also needs doing as the sterring wheel is at an angle but it does not pull to the left or right
the car had a light front end crash in 2007 which is on the log book and says it has had an identitiy check. The person i bought it from said it had a bumper front wing and a head lamp cover.
Email me or phone me on 07528551142
it is also on ebay http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :MESELX:IT
im after £1600 for it im open to px's or swaps
