I would have thought that you need to replace both rear wheel bearings.
This is not really a job you can do yourself as I understand that you need a special peice of kit to
'press' the new bearings on.
Did you get a quote? Any info from the garage as to what they thought was involved?
Maybe get another garage to give a second opinion before you comit to replacing the bearings, it may be something else susp.
related.
Oh
- and if your doing your wheel bearings you might want to replace or remove the splash/dust brake disc guards.
These are held in place by 3-4 torque screws
- the guards are usually sh*agged and look ugly.
and if your replacing the bearings it is a complementary job.
.just a thought anyway
