Oild pressure Temp sender mounts
stevecruiz
Post by stevecruiz »
Hi guys,
Bought a pair of oil temp/pressure gauges. I tried mounting there senders with the usual sandwhich plate but there was to many bits and bobs in the way blocking a nice seal, then spaying oil all over the place when starting up and testing.
I was told I can mount the Oil pressure gauge sender, in the factory oil light sender position on the top of the block, and im told that I can mount the oil temp sender in the sump plug.
The question is does anyone know what thread sizes these are so I can get the adaptors from R-spec.
Many thanks,
Steve
Slarty
Re: Oild pressure Temp sender mounts
Post by Slarty »
toxo
Post by toxo »
Slarty wrote:
Also, for the oil temperature;
http://www.demon-tweeks.co.uk/products/ ... &x=29&y=10
God bless the search ;)
That link doesn't work since DT redesigned their site, but I guess it would be a link to something like this:
http://www.demon-tweeks.co.uk/Performan ... r/812/1844
Slarty
Post by Slarty »
Ah nice one Toxo, I'd copied the link from an old post it would seem.
stevecruiz
Nice one will buy that for the oil temp sender, has anyone else had issues with the oil filter sandwich plates??
