i removed mine the other week to do this exact job, but also did remove all the induction to replace all gaskets.
from memory, remove the throttle cable,
then 2 bolts for the bracket with the
"s" shaped raised piece
(just to the left of the throttle body in the above pic),
then remove the throttle cable bracket one step further to the left,
then the 4 bolts holding the throttle cable guide again one step to the left.
the inlet will no longer be
"attached" to the engine top.
continuing, remove the 4 bolts holding the throttle body to the inlet end,
remove the 5 bolts and 2 nuts holding the inlet to the secondary inlet section.
this is all the fixings for the
"toyota" labled section of the inlet.
i found that holding the labled end of the inlet and gently moving it up and down
(too and from the cam cover) slowly seporated the gasket on the join to the second section of inlet.
it should slowly come away
then you have all the bolts for the cover
what cam gasket kit did you get?
