maximum weight loss tips please
Re: maximum weight loss tips please
i have been told that this will save 2 kgs but surely the aeros will not be as good in the day? obviously better if lights need to be on the flush style used on the japenese racers would be the bomb if they were light
best of both worlds but not sure of weight and cost etc
I didn't get my alternator bracket fitted today due to getting my Phoenix power adjustable rear control arms fitted instead and going for alignment.
For those interested in the weights:
Stock rear control arm 4.3kg
Phoenix power rear control arm 3.1kg
Total weight saving a tremendous 2.4kg for both sides
Added bling factor
+100%
Added bling factor
so who would make these items?????
swampy wrote:so who would make these items?????
Mine were made by a Japanese tuning company called Phoenix Power but I believe they might be discontinued now.
However there is a vendor on the American MR2OC.COM forum that was talking about making similar units but he put a post up that recently that they have been put on the back burner for a while due to having too much work to catch up on.
cheers for that, guess i could also look for a local engineering cnc company and get a price.
How about this then, ditch some unsprung and rotational mass!
Rev 2> 276x31mm
WMS 298.5x18mm
That's a 5.65kg saving
per wheel
at the front, and with the
(full race only, handbrakeless) rear WMS kits as well the total might/should top 20kg saved.
.plus bigger brakes of course!
Rev 2> 276x31mm
WMS 298.5x18mm
WMS 4 pot brake kits in Affiliates! Mk1:
www.imoc.co.uk/forums/viewtopic.php?t=128889
& Mk2:
www.imoc.co.uk/forums/viewtopic.php?t=140657
kaiowas wrote:/Edit never mind, I worked it out
Too late, the email went out!
& Mk2:
Keri-WMS wrote:kaiowas wrote:/Edit never mind, I worked it out
Too late, the email went out!![]()
Thought as much
In my defence the carrier on a mk1 is nowhere near as substantial.
kaiowas wrote:Keri-WMS wrote:kaiowas wrote:/Edit never mind, I worked it out
Thought as much![]()
Very true.
& Mk2:
Just started on my car here is a few photos of the cabin before i get the roll cage in there
Keri-WMS wrote:How about this then, ditch some unsprung and rotational mass!
Rev 2> 276x31mm
http://i279.photobucket.com/albums/kk15 ... v-2-on.jpg
WMS 298.5x18mm
http://i279.photobucket.com/albums/kk15 ... 0181-f.jpg
That's a 5.65kg savingper wheel
These look lovely
Is the weight saving in the caliper or the disc? How does the individual brake disc and caliper compare weight wise to the stock items when weighed on their own?
Would it be possible to release a version that allowed people to keep their 15's as I like the idea of saving weight but still want the option to swap on some 15's?
Btw I ended up getting a billet alternator bracket kit from the US forums that weighed a little under 900g in the end.
Kongaroo wrote:
Btw I ended up getting a billet alternator bracket kit from the US forums that weighed a little under 900g in the end.The standard rev 3 turbo alternator bracket is 4.9kg so saved about 4kg there in the end
Ooohhh- link? Is it a copy of the std one?
Kongaroo wrote:These look lovely![]()
Ta!
Kongaroo wrote:Is the weight saving in the caliper or the disc? How does the individual brake disc and caliper compare weight wise to the stock items when weighed on their own?
It's a bit of both!
WMS caliper+bracket+bolts+pads
Rev2 caliper+carrier+bolts+pads
WMS 298.5x18 disc
Rev2 276x32 disc
Kongaroo wrote:Would it be possible to release a version that allowed people to keep their 15's as I like the idea of saving weight but still want the option to swap on some 15's?
I've got that in mind for the future, but it's actually not easy to do due to the shape of the 15" SW20 front wheel.
See what I mean, look at the lugs:
& Mk2:
They look nice but personally I've never heard of them before
Where'd you get them from? I went on a quick search but to no avail!
Any idea of the price on these?
Rubber Chicken wrote:They look nice but personally I've never heard of them before
We've been around for years with the Mk1 MR2 kit
We're hidden away in affiliates where the prices etc are.
Mk1
Mk2
& Mk2:
Hi mate, here is the link to the one I bought from the US forum:
http://mr2oc.com/showthread.php?t=39578 ... ht=bracket
After UK postage, VAT and customs clearance fees were added it came to about
They got the weight slightly wrong as it isn't quite as light as 1.5lbs
Peter mentioned that it needed a small washer to space it out slightly as the head of the adjuster arm rubbed against the engine mounting
I still have the other light weight cast alloy alternator bracket which is a copy of the stock bracket but much lighter at 1.9kg.
Keri-WMS wrote:Kongaroo wrote:These look lovely![]()
Ta!![]()
It's a bit of both!
WMS caliper+bracket+bolts+pads= 2.39kg
Rev2 caliper+carrier+bolts+pads= 5.79kg
WMS 298.5x18 disc= 4.99kg
(so 5.0kg spec?)
Rev2 276x32 disc= 7.46kg
(so 7.5kg spec?)
I've got that in mind for the future, but it's actually not easy to do due to the shape of the 15" SW20 front wheel..
! Also the WMS T20 caliper is pretty tight to the lugs on the strut as-is, so I'll need to do a lot of messing about to make it happen.
http://i279.photobucket.com/albums/kk15 ... 0181-b.jpg
Thanks for the info.
Kongaroo wrote:Thanks for the info.![]()
- I would definitely be interested in a light weight brake setup that performed as well as or slightly better than stock but still fit under 15's.
That way I could still keep a selection of different alloys.
Although I love my 16's and 17's I couldn't sell on my 15" TE37s or Buddyclubs
No problem.
The OEM MR2 15's are a no-go though.
& Mk2:
Right guys, going off topic here.
If you goign to discuss the brakes, please do so in a seperate thread rather than on here.
Keep this to weight saving, not brake discussion.
Thank you.
Thank you.
