[Mk2] [Turbo] High Flow Oil and Water Pumps
Shmed
Post by Shmed »
Are they needed on a 400-500 bhp track car?
I know (from using the search) that Nathan's drag car used stock pumps, but I'm not looking to drag my car, and tbh I imagine a day on the track is harder on the oil/cooling system thatn a drag run?!
Need to know asap please as I am about to order my engine bits, and need to decide whether to go for a new OEM item, or uprated.
Thanks All
Steve-m-uk
Re: [Mk2] [Turbo] High Flow Oil and Water Pumps
Post by Steve-m-uk »
I think a stock water pump is fine but if you intend to surpass the stock rev limit which i presume you will with a 500bhp car then you will want to be looking at a high volume aftermarket oil pump.
jdbecks
Post by jdbecks »
you dont need a bigger oil pump
for the long technical answer do a search on www.mr2oc.com written by Bill Wot.
greeny
Post by greeny »
Id use a 5sfe oil pump!
jdbecks
Post by jdbecks »
The 3sgte oil pump will always be able to provide enough flow no matter what the rpm.
GTS GAV
Post by GTS GAV »
Im raising my rev limet to nearly 9grand with stock oil pump many have done so with out problems :thumleft:
stock isnt that soup or something.....?
tic tac 500bhp build thread
http://www.imoc.co.uk/forums/viewtopic. ... 57#1182357
Shmed
Post by Shmed »
Good stuff, cheers all, I've ordered a new oem oil and water pump. Gav, I'm aiming to rev around the same, so I'll keep an eye out for your 'my car has blown up' thread so I know if you are right ;)
GTS GAV
Post by GTS GAV »
haha no worries but not goin to happen buddy :mrgreen: i no of atleast 6 guys who have set there limet to 9k and the stock oil pump was more than man enough, you may see one saying gav wheelies into a tree, mr2 is dead thread :lol: :lol: :lol: :lol:
hope all goes well with your build buddy :thumleft:
Shmed
Post by Shmed »
:lol: try not to wheelie into any trees! I hope the build lands up half as good as yours mate, doubt it will though, one man, his shed and lots of helpful forum folk should see me through!
GTS GAV
Post by GTS GAV »
:lol: will try my hardest lol cheers buddy its been a long 13moths of hard graft iv also had alot of help from members on here with advise and parts has been a massive help, and if you need any help just drop me a message anytime :thumleft: im sure your two will look the dogs danglies with all the bits you have been buying recently :thumleft: looking foward to seing a build thread 8)
Shmed
Post by Shmed »
Yeah, im in the parts aquisition phase, seems that I just buy everything and decide whether I need it later....
Ordered all my engine internals the other day so should be able to start building soon. I'll hopefully get round to a build thread too!
Century Motorsport
Post by Century Motorsport »
The rev3 pump is a bit more reliable than the rev 1/2 IIRC ... a popular option for the rev 1/2 was the Chris K pump .. dont know if its still available.
I would imagine that a stock pump should do you fine. Its only really high RPM where std pumps have issues.
Gaz 9krpm is getting there! I would have though that much more than that and you'd be getting cavitation issues... which you certainly don't want!
Builders of the the UK's first 9second MR2 - 9.722 @ 148 MPH ----- 07947883103 ---- www.centurymotorsport.com
GTS GAV
Post by GTS GAV »
Hey there nathen how's it going bud, yeah think 9k is pritty much the limitsi will probably keep it to a modest 8500k just to be on the safer side, what pump did you run and what was you rev limit set too?
Century Motorsport
I ran a stock rev 3 buddy and only revved to a meagre 8,5k ... that was with a gt40 so what the hell turbo are you running to warrent revving to 9k?!
GTS GAV
Post by GTS GAV »
I was just goin to go with a a 35R with a/r of 1.06 see how far it would let me take it lol I would be happy with 8k if I can go higher all the better :) one thing I thort I would ask is did you go with a shimless bucket conversion on your head?
Century Motorsport
Cool! That will be a rev monster with that exhaust housing ;)
I just ran rev 3 shim under bucket followers ... with the head being off every 5 mins and valves seats being re cut the clearance always changed for it was far easier (and cheaper) to get a new shim than get a new bucket!
GTS GAV
Post by GTS GAV »
Thats the plan bud, that will to show those crazy turbo vtec's a thing or two :lol: :lol:
If only i had that oppertunity there simply isnt enough time in the day, i will probably go shimless buckets after its been run in
Im looking into the jun 272 highlift cams, im running Hks 264's at the moment but want to push the power band up as much as poss, iv spoken to alot of 2 owners about the Hks 272's being impossible to set up 100% correctly, im taking a punt on the jun's being better deisghned have you hurd anyone run juns before?
greeny
Post by greeny »
Who cant get the 272's setup gav?
Have they degree'd them?
GTS GAV
Post by GTS GAV »
It was when I spoke to chris and andy f they both couldn't get them set up 100percent and have hurd others have had problem from the best as I can remember I'm sure it was mentioned that hks designed them around the hks na cams or something along those lines, what's cams are you running michael?
Century Motorsport
I didn't get any issues with my HKS 272's .. i remember running 141 terminal on 272's, no nos and a gt35 :twisted:
