discs: I got my OEM style discs from twosrus but I think the UK arm has closed now.
I'm sure the affliaites section has suppliers listed but any of the big motor factors will be able to order them for you.
pads: I used std pads as they worked fine from cold and didn't break apart either.
Carbotec's are reckoned to be the best pad upgrade as the fast road pad works from cold and is very good when hot.
The dust though is appalling and eats your wheels and they squeak when cold
/ not used hard.
However pound for pound straight swap they are supposed to be the best OEM style replacement for performance upgrade.
now, I run different discs all round different fronts but any of the track day guys will pipe up with stock style replacements
(they all run 15's so don't change dissc size or calipers
