PS3 Home page poor quality
Is the PS3 better than a C64, all in here
bri0905
Post by bri0905 »
HI,
Recently i've noticed that the first page that loads when i switch on the ps3 is much fuzzier than it used to be. Not the great quality that i used to see. Still brilliant in games and watching bluray.
No cables have changed or come loose and the tv is the same.
Any ideas?
96 Rev 3 Turbo, Done!
DannyN
Re: PS3 Home page poor quality
Post by DannyN »
Sounds like your power has gone off and its reset itself to a lower resolution
bri0905
Post by bri0905 »
Might be the case, How do i change it back?
fizz
Post by fizz »
Display options.. then you select HDMI and then manual config i think... then you should be able to choose the different resolution options.
bri0905
Post by bri0905 »
Thanks guys i'll try that.
Return to “Games Consoles”
