liamdavies wrote:odometer clocks up miles when ignition is turned on ??
Do you mean the odo clocks up a few miles each time you turn the ignition on even though you're stationary?
It will do this if you have one of the stef derner clamping delimeters and it's set to the test mode where the speedo needle goes to 120, 60 then back to zero on the speedo each time you turn the ignition on. Turn the test function off, problem sorted
