[Mk2] [NA] Aerial problems and wiring, need help.
sangyboymr2
Post by sangyboymr2 »
Ok, so the original leccy aerial is broke due to the previous owner taking it thru the car wash with it fully up!
I have bought a replacement non standard one from ebay that will fit toyota mr2's up to 1999. Mine being a K plate fits that description.
I've removed the old one fine following an online guide. Trying to get the new one in is the problem. It's not exactly the same as the standard part, a little smaller with only 3 wires and the aerial co-axail. The latter fits fine!
The orig part has a wire block containing 6 wires which did just plug in. New part has 3 wires. A black earth. A red and a blue with no connectors.
So i can bolt it in fin but the wirings got me.
Any help will be gratefully recieved.
The wire colours going into the original block are black/white, red, blue/pink, green/black, black/yellow, grey.
toxo
Re: [Mk2] [NA] Aerial problems and wiring, need help.
Post by toxo »
I know it's for a MK1 so the wire colours aren't right, but from this guide with a multimeter you should be able to work out what wires are what and go from there.
http://www.basirk.com/mr2/maintenance/aerial.html
Mike
Post by Mike »
How did you get the old one out? I've tried following the guide but I wasn't very successfull.
toxo
Post by toxo »
I've not done it myself as my aerial still works :lol: which bit are you stuck on?
