In my opinion the only thing the car needs to bring it up to show car standard is some TLC to the interior.
In the last year I have carried out the following work:
New steel head gasket
New cambelt
Re-conditioned turbo, fitted fuel cut defender and fixed air leak around manifold
Had oil leak repaired around crankshaft
Four new tyres still with loads of tread on
I'm sure I've forgotten some bits and bobs but I have receipts for all works carried out since I bought the car.
Rev 3 conversion carried out on ECU by Rogue Motorsport.
Current mileage: 61, 982
Below is the specification of the car, if any further information is required please call me or email and Ill answer as best I can.
As the car is my daily driver I have the boost set at a sensible level, however with the manifold set up and turbo the car could easily produce more power if desired.
Negative points:
Some wear on the drivers side seat, may need a little TLC
Couple of small scratches on the windows
Alarm has currently been deactivated as it was very erratic!
Bearing slightly worn on clutch.
I know most people on here are into the details so I have listed everything as best I can below.
1991
2.0 16v turbo
1st uk owner purchased in 2002
Toyota super red
GT model:
Electric Windows
Central locking
Tbar
Air-con
Trace fog lights
Power steering
Tilt adjust steering
Modification list:
Engine
XS 3" stainless downpipe
XS Active External waste-gate 10 psi spring
Aircon removed
Apexi Intake
Full Stainless Blitz Nur Exhaust
Blitz plugs grade 8
Carbon canister Removed
Coolant pipes reworked
Custom cooler pipe work
Custom intake pipe
Custom XS Screamer
Engine dress
Engine rebuild to Toyota rev 3 spec
Garrett T3 hybrid turbo
Greddy Catch can
Greddy Circle earth kit
Greddy sidemount cooler with hard pipe kit
HKS Cam Gears
HKS Cams 264
HKS SSQV BOV
Magnacor leads
Mikalor clamps
Toyota Rev 2 Throttle body
Toyota Rev 4 ECU
Toyota Rev 4 FPR
Toyota Rev 4 Injectors
Rouge Engine fans
Solid engine mounts
Samco hose kit
steel Head gasket
Head ported and polished
New Valve stem seats
XS Tubular manifold
TViS removed
Walbro Fuel pump 255 TBF
Silkolene pro 10/40w
Transmission
Helix stage 2 puck clutch
MT90 Fluid
Solid Shift bushes
Speedo converter to mph
TRD short shift
Up-rated Slave cylinder rod fro smoother gear change
Suspension
Adjustable drop links
ARB bushes
Cusco brace
Fensport 40mm springs
High and tight bushes
KYB shocks
Brakes
Brake stopper
Carbotech pads
Goodridge hoses
Toyota Rev 3 Disk, calliper and pad upgrade
Alloys
25mm rear spacers
Breyton Magic R's 17" x 8"
Exterior
500k lights
Phoenix power front bumper with extension lip and moulded headlights
Meshed grill
Bomex side skirts
Bomex rear spats
Veilside rear wing
Full Toyota super red re-spray
Colour coded rubbing strips
Clear lenses
MRD flat rear panel
Tinted rear 1/4's
Interior
Alumnium dash insert and white dials
Blitz Turbo timer
Colour coded mats
Field Boost control
Field Scramble control
Field Fuel control
Field Switch control
Gauge's
Greddy Power stabiliser
HKS Fuel monitor
Momo Gear Knob and Steering wheel
Sparco foot pedals
Auto gauge Tachometer
Audio
Infinity door speakers
Pioneer 6x9
Pioneer double face
I cant figure out how to embed photos lol so for the time being here is a link to my autotrader ad where there are some photos.
http://www.autotrader.co.uk/classified/ ... ?logcode=p
Thanks for looking
