When the flywheel was removed had a visual inspection of the rear main oil seal and all look well so i left it well alone.
After putting the car back together left it running for 2 minutes and it started losing engine oil over the floor
The oil is leaking from what looks like between the engine and tranny and dripping from the sump.
I have removed the flywheel inspection cover and can see no oil inside gearbox casing or on flywheel, So i assume the leak is either from sump gasket or rear main oil seal.
My question is
The car only leaks after it has been running for a few minutes.
Many Thanks
Mark
