i dont really understand your issue??
ever thought that your old setup you were boost creeping?? due to the stock wastegate.
perhaps your new turbo has a better wastegate and you simply dont suffer from boost creep anymore.
hense why you get higher boost on the old setup.
do you have a boost controller?
if not, your questions do NOT make sense.
if your question were, ive swapped the turbo and i cant boost more than 0.9bar with a boost controller, then that would be a question we can help with.
but if your not running a boost controller, then 0.9bar is PERFECTLY normal.
0.9bar after all is standard boost!
if you want more boost, you need a boost controller.
to disbaled TVSV, you need to block that second actuator line that goes to the tvsv, or simply unplug the blue tvsv plug.
but you cant just leave that 2nd pipe exposed.
