Remapping wouldn't work simply as the standard ECU isn't
(yet) remappable.
Piggy backs? In my opinion, no, utter garbage.
If you want to alter the mapping, get a proper stand alone such as a PFC etc.
As for not using a boost controller on a standard turbo? Whoever told you the car only lasted 6 miles must have done a pretty bad job of installing/setting up the boost controller.
Set properly they're fine, to a point.
You have to realise that increasing an engines power is ALWAYS going to affect reliability to some extent, at some point.
It might last 50,000 miles without a hitch, it might not.
It's the risk you take.
As for hitting 300 bhp on a side mount, it's very possible, several members have done so.
It's also car/engine dependant.
Some stock cars will make strong power, some wont so based on that some will only need a small boost increase and some breathing mods and some will fall short with the above mods.
