Hi Iain
I assume you mean the threaded tubes that sleeve the strut
after you have removed the regular spring seat?
Yes I have used them
but if you factor in the springs
dampers
and top mounts
bump stops
you might as well go for new BC ones?
The cost saving is negligible.
Stephen
