I had this with a megane worked it out too be that the ABS ring on the shaft was incorrect.
The sensor is fairly simple, metal passing by a magnet to generate a voltage.
the voltage will increase and decrease dependant on speed.
If the sensor is slightly too far away at low speeds i will not generate enough voltage to send a signal to the ECU.
ECU reconises the wheel as being locked therefore applies the ABS.
May be something totally diffrent.
I ended up having to fit a new shaft as the wrong one had been fitted.
