ABS
rickymcg
ABS
Post by rickymcg »
Hi Chaps
Car went for MOT tonight but didnt make it through ABS light on the dash wasn't coming on and the rear sensor wires have been removed #-o don't know what the pervious owner was thinking. Anyway is it a big job to replace the sensors and will any rev2 ones fit or are turbo rev 2 ones different ?
Cheers :thumleft: \
Ricky
rickymcg
Re: ABS
Post by rickymcg »
Hi chaps
Can anyone shed some light on this topic for me ?
cheers :thumleft:
Ricky
mmk
Re: ABS
Post by mmk »
The reason someone's taken them off is most likely that they broke when they had to remove them for some reason (usually replacing wheel bearings). New ones can be quite pricey.
It's not really a big deal to put new ones in, but you have to be really careful handling the sensors because they're quite fragile. Google for 'mr2 abs sensor' -- one of the first hits is a thorough guide for replacing them.
As far as I can see the parts are the same for the NA and Turbo cars -- the part numbers do seem to match. Just make sure you still do have the cable ends + connectors in the engine bay.
rickymcg
Re: ABS
Post by rickymcg »
Thats great news :pray: thank you very much I should now be able to get a cheap pair off an n/a that is getting broken locally.
Cheers :thumleft:
Ricky
rickymcg
Re: ABS
Post by rickymcg »
Hi chaps
Dam no luck where would I get cheap Sensor ? Or is everywhere gonna be 140 per sensor please say there are cheaper places as that seems a bit of a rip off ?
Cheers :thumleft:
Ricky
Shmed
Re: ABS
Post by Shmed »
Is working ABS a requirement for MOT? I thought it was done on braking 'power' (for want of a better word).
rickymcg
Re: ABS
Post by rickymcg »
I think i can bluff it as long as I can get my ABS dash light to function correctly as in turns off after 3 seconds once engine is started. however he noticed the sensors on the rear hubs had been removed so i might have to attach a suitable bit of cable and fitting to bluff it then I can source sensors at a later stage.
Cheers :thumleft:
Ricky
loudandproud205
IMOC Organiser
Re: ABS
Post by loudandproud205 »
remove the full lot and pull light out of the panel
rev1 abs is poo anyway
Chaps110
Re: ABS
Post by Chaps110 »
My mate has just broken his old Mk2 Rev 2 N/a. I know he's got rid of most of the panels and the stripped down shell but we did take the engine out (the engine is completely dead) with the idea that he'd sell on all the sensors. If you think his might work for you pm me and i'll get in touch with him. He is a member on here but i've no idea what his username is...
rickymcg
Re: ABS
Post by rickymcg »
What MR2's came with ABS is it just turbos and imports ?
Ricky
Chaps110
Re: ABS
Post by Chaps110 »
Forgot to say, the one that we broke was an import rev 3 n/a
