My car has been lowered 30mm courtesy of the koni kit I've got installed, bearing this in mind, will I need shorter drop links or will the roll bars fit perfectly regardless of the drop?
SuperRedMR2 wrote:oh you actually get drop links with the front one?
kaiowas wrote:SuperRedMR2 wrote:oh you actually get drop links with the front one?
You do but they're useless.They're just a length of metal bar bent into a loop around a rubber bush at each end.
Unfortunately this makes them too big to fit inside the bracket on the shock casing so your only option is to fit them outside the bracket where they'll foul the inner arch when the suspension compresses.
In summary don't bother with them.
