Should i go for OEM ones or any aftermarket bearings? (if available)
Does anyone know ere to get these or have toyotas product number for these.
I also need a new crank if anyone can help me.
And some gaskets.
thanks
This is probably the 5th bearing post in the past week Check the other posts everything you need answered is covered.
Toyota will sell you an engine seal kit if you need one.
James
