Front Wheel Bearings
Is it possible to buy just wheel bearings for the front or do you have to buy the whole wheel bearing hub unit?
Re: Front Wheel Bearings
You can't change the bearing itself, its a complete unit
- bearing, hub, abs sensor etc.
Part number 43550-17010
- about
£200.
thanks,
i'm also getting a slight shuddering on braking.
I was wondering if that could be something to do with a faulty abs sensor.
Thats one expensive part!
impgrrrl wrote:
i'm also getting a slight shuddering on braking.I was wondering if that could be something to do with a faulty abs sensor.
No it won't be anything to do with your ABS sensor.
Check disc runout for warping.
