VERY annoying problem! Basically broke my petrol needle fitting lockwood gauges.
.was supplied with a second hand gauge that i fitted
'carefully' this time lol.
After new gauge was fitted i set the needle at empty as i knew i had no fuel as my low light was on.
Started car and the needle started moving DOWN till it was VERTICALLY down?! Tried moving the needle back to empty, but again it moved back to its vertical position!
Put
£35 in and it moved up slowly to 1/4 tank!!
(its almost like the gauge is about 1/4 tank out) This is the weird part though.
Got to my car yeaterday morning to go to work and it was at half a tank
(i hadnt moved it, and this is where the gauge should have been) Soon as i started the car it dropped to 1/4 tank.
Ran around in it yesterday then went to work.
.came out and it was at 1/4?!!
(which is where it should have been as i reckon i used 1/4 tank over the day) But again i started the car and it bloody moved to under the empty position again!
Its like its resetting itself correctly when the car is off, then as soon as it has power, its dropping!!
Only thing i did notice on the 2nd hand gauge was that it had a different
'code' on the side of it to the gauge i had broken
Please help!! Cheers in advance!
Darren
