[Mk2] [Turbo] chargecooler pump
Apocalypse
Post by Apocalypse »
Hi guys,
On my chargecooler I'm running the standard st205 water pump. It looks to have failed this morning as I can't hear it running and no movement in the water.
Looking to replace with a better pump. I know it has been done but I'm unsure of which pump I need.
Please can someone link me to some options as I need one asap.
Cheers guys
Re: [Mk2] [Turbo] chargecooler pump
Post by Martin F »
Are there not parts you can buy to get the st205 pump back up and running, though i read before they were around £10 and a 45min job :-k
Apocalypse
I've got no idea,... tried searching for previous threads on the subject but no luck
Post by Martin F »
Apocalypse wrote:I've got no idea,... tried searching for previous threads on the subject but no luck
http://www.imoc.co.uk/forums/viewtopic. ... ooler+pump
They are probably of little help but i'm getting many pages of results, just choose your search words carefully then search through all the posts until you come across what your looking for, remember to tick the lower box Btw :wink:
Peter Gidden
Post by Peter Gidden »
Bosch pump - ebay - about £110 delivered. As used on Audi TTs. Can't fault quality.
Here you go:
http://cgi.ebay.co.uk/Bosch-PAD-12V-Veh ... 35a808cefb
raptor95GTS
Post by raptor95GTS »
nah rebuild the GT4 unit it's cheaper and a much better pump or if you are buying a new pump get the marine units ones.
Apocalypse
Do you know how it's done or where to get it done?
dantheman
Post by dantheman »
http://cgi.ebay.co.uk/AVT-Bosch-Chargec ... 3efea7ea74
just put that one in mine. supposed to be very reliable
Peter Gidden
dantheman wrote:http://cgi.ebay.co.uk/AVT-Bosch-Chargec ... 3efea7ea74
Good choice :thumleft:
raptor95GTS
Apocalypse wrote:Do you know how it's done or where to get it done?
http://www.gtfours.co.uk/ then How To -> go to Repair / Maintain -> overhaul IC Pump -> 205
for pumps it's important to get a figure for what happens when it's pumping against resistance and there's a fair amount of pipework any mr2 setup. Wish I'd done some more research before going down the cc path (then coming back to stock lol)
http://www.imoc.co.uk/forums/viewtopic. ... highlight=
