Car
= Rev4 GTS turbo.
My piston rings recently went requiring a bottom end rebuild, i had a new piston in no.
4 and all pistons had new rings fitted.
The symptoms of this problem were low compression on cylinder 4, oil smoking out the dump valve and the engine warning light reporting knock sensor.
I got the car back and i'm currently 400 miles into running it in.
2 minutes into a short journey yesterday, the engine warning light comes on.
I check the error and it's error 52 knock sensor.
I've read on here that the knock sensor detects engine noise.
Is it likely that something has gone seriously wrong again? or does it simply need a new sensor? or could it be something completely different?
Please help!
