regards
Disconnect the following..
Engine bay fan
Alternator plug
Engine bay fan relay
Combination meter
Now do a continuity test between the Yellow wire on your alternator plug to earth, there should be no continuity at all between that wire and ground(batt
-) with everything disconnected.
Try plugging the alternator back in, start the engine, and prod the yellow wire at the alt with a multimeter, and at the N1 connector, both sides of it.You should be seeing 14.5v at all of those points of the yellow wire with the engine running, but i don't think you will be.
Report back with your findings.
Just another after thought- as part of the rebuild I obviously painted the alternator brackets and engine block
-- i thought that the thread of the bracket/mounting bolts would be enough to earth
(if there meant to earth at all) but you dont think this could be a alternator earthing issue???
Just been out and checked on my car.![]()
My apologies I was working off of the diagrams and got the orientation wrong
With the Charge fuse out and ignition on
Left side of the fuse holder should show less the 1v.![]()
Right side should be battery voltage(call it 12V)
and no lights on the dash
Still with the fuse out and now with the engine running
Left side should show around 13.8v( alternator output voltage)
Right side should be approx the same.![]()
Quote:
I get 13.8v with the engine running on the right side and.36v on the left???
Going by this you either have a faulty alternator(unlikely as you have tried several) or a open circuit in the wiring between the alternator and the fuse
(odds on favourite)
To prove it you can use a length of wire to link between the L terminal of the alternator(you will need to keep the plug in the alt and link from the back of it) and the Right hand side of the fuseholder.
The dash lights should go out.
Also check the voltage on the L terminal of the alternator from the back of the plug with the plug in and engine running, should be around 13.8v, if it's not then could be a bad contact in the plug or the alternator is faulty.![]()
Alternator terminals
