I went out in my mr2 rev 3 NA today done a 2 hour motorway journey no problems.
I then stopped on my drive, the car
It still seems to run low on idle now and then, but also it seemed to stutter at about 2000rpm when under light/low acceleration.
Also the temperature gauge seem to have stopped working correctly, it was staying on low
I can also hear a bubbling noise inside sounds like from behind the dash where the radio is but not sure.
The alternator belt was slipping a bit and squeeking when first started but soon stops after about 20secs.
The car has been fitted with a
Should I be worrying and be prepared to dig deep into my pockets???
I was wondering if the temp gauge could be registering a low temp if there was an air pocket around the sensor??? is that possible.
Worst nightmare could it be the beginning of head gasket failure???
any help appreciate,
Joe
