not push starting...
Ed209
Post by Ed209 »
hi all - i have a problem in that my starter was on its way out. so to startup i was tapping the starter motor for a while then the car would start. thats doesnt work anymore, time to take to garage and get a new starter motor, but now the car wont push/jump start either (it was before). theres nothing. the battery is fine and all electrics work. anyone any idea?
thanks
Quigonjay
Re: not push starting...
Post by Quigonjay »
kind of answered your own question there mate
was freeing up with tapping, now it isnt :idea:
Si_Crewe
Post by Si_Crewe »
Might not be the starter that's goosed but the solenoid instead.
I had the same problem with a Land Rover a few years ago.
I used to thump it with a big screwdriver if it failed to start.
One day I slipped with the screwdriver and accidentally shorted-out the contact from the solenoid to the starter motor.
This made the starter motor turn over properly and, after that, if it wouldn't start on the key I could leave the ignition on, short out the solenoid and get it to start perfectly every time.
IF you're happy to play with big lumps of electricity you might try something similar... if you can see the solenoid on a 2 engine.
Be warned though, you're playing with serious amounts of leccy and getting it wrong could melt the wiring, screw up the ECU or set the car on fire.
After 6 months of regularly starting my Landie with the screwdriver I gave up and got a new starter fitted and wished I'd done it straight away.
Ed209
Post by Ed209 »
thanks for the replies...i was kinda wondering though why the car isnt starting with a push start though, i know the starter motor and or solenoid is bu88ered but now it wont start with a push either.
thanks..
