washer not working
luke t
washer not working
Post by luke t »
since the bad weather i havnt used my washer for the screen
tried today and nothin, not even a noise
any help?
michael
Re: washer not working
Post by michael »
luke t wrote:since the bad weather i havnt used my washer for the screen
any help?
What's the temp been like where you are?
Is the mix you're using up to the temps?
The washers on one of my cars stayed frozen for a few days recently.
Try refilling the system with warm / hot (not boiling) water with a decent amount of screenwash in.
toxo
Post by toxo »
Could be all sorts of things. Usually if the jets are frozen you at least get a noise from the pump. Pump could be frozen. If the washer fluid is too dilute then the fluid itself could be frozen...
I would be taking the driver's front wheel + arch liner off. This affords you access to the tank, pump and pipework.
Edit: At least, that's what I'd be doing after following Michael's advice :thumleft:
Oh and BTW if it is the pump, you can get a replacement from Halfords pretty cheap.
