dump valve help please
RobCrezz
Re: dump valve help please
Post by RobCrezz »
jaywb wrote:will i still get the dump valve dump noise if i use the resirk way with the hks?
I think you do with the HKS although not as loud as full vent to atmos, but if you wanted vent to atmos you should do a Rev3 conversion (and get more power as a bonus).
This guy has it recirculating and you can still hear it, not an MR2 though:
http://www.youtube.com/watch?v=C-cJybfBnTs
notroubleclubber
Post by notroubleclubber »
Ive managed to get hold of a standard bov locally so swapped out my old hks one (which was bidged on anyway when i bought it). No more tish (apart from a very low one) but ive found that fuel hasnt improved and now i have a flat spot mid range. Its plumbed in correctly and ive reset the ecu.
What could be the prob? Im running a rev2 tubby.
RobCrezz
Post by RobCrezz »
notroubleclubber wrote:Ive managed to get hold of a standard bov locally so swapped out my old hks one (which was bidged on anyway when i bought it). No more tish (apart from a very low one) but ive found that fuel hasnt improved and now i have a flat spot mid range. Its plumbed in correctly and ive reset the ecu.
Boost or vacume leak! Check the hoses and connectors are tight!
