[Mk2] [Turbo] rev3 head on rev2 block
Chris
Re: [Mk2] [Turbo] rev3 head on rev2 block
Post by Chris »
Thank you for the link, we can all get our cars sorted now....
87mm rebore on his own HIGHLY modified car #-o Obviously a real pro tuner for the MR2 :lol: :clap:
His block is a ticking timebomb!!! Book me in boys! :clown:
JJ
Post by JJ »
Rev 1 to Rev 3 head just the other month.. Rev 3 head gasket fitted with no issues ! :thumleft:
One thing I will say, its not just quite plug and play.. few things need to be modified to fit .. ie... The bypass / water matrix needs the bracket cutting off that attaches to the original head as it makes contact with the rev 3 head....
Rev 3 head.. you need all components as mentioned... makes your life easier.... cam gears, manifolds, timing tensioner.. cam cover, throttle body ( thanks Chris ! :thumleft: ) catch can, even the injector rail... but can ustilise the earlier belt.... it'll all work... Most importantly is you need the sensor array / swirl pot - this is unique to the rev 3 head and cannot be interchanged....
Need to bend the oil feel pipe to the turbo partically, its brittle at the flange.. so caution when doing this...
Benefits - Gas Flow !! You increase gas flow through the engine, you can achieve anything ! :thumleft:
greeny
Post by greeny »
Chris wrote:Thank you for the link, we can all get our cars sorted now....
Hey whats up with 87mm bore....... :whistle: :mrgreen:
