I was looking for supplies to build myself a small bass amp, and found this little device in kit form at Maplin for
£9.99
http://www.electronictoolbox.com/000043 ... ition.html
any idea if it's worth trying? If you're handy with a soldering iron, might be worth it.
give me a few weeks, maybe i'll have one installed.
anyone know if a mk1 mr2 has a negative ground?
their blurb:
Gives your car the feel of an expensive luxury car.
Better starting and smoother running, particularly at very high and very low RPM.
Lower fuel consumption, less pollution, lower servicing costs.
Drive economically, drive electronically.
Only for petrol/gasoline engines.
Only for cars with negative ground.
Specifications
* max.
current: 4A
* connection speed: up to 500kHz
* PCB dimensions: 2.8" x 1.4"
* recommended housing: G304 Extra Info
- Hints
* o For use on a 6V system replace next parts
+ R1 and R2
: 150 ohm
/ 1W
+ R3
: 68 ohm 1/4W
+ R5, R6 and R7
: 68 ohm
/ 1W
