Do i need a special Lamdba Sensor?
OKI
Post by OKI »
Hi all,
Its been a while. I have a quicky for you!
I've been told i need a new Lamdba sensor. The cars heavily tuned, do I need a special lamdba sensor or will the stock one do?
The plastic connectors which connect the sensor cable to rest of the cables has melted severely, so i will need to replace them also.
Any ideas where I can source these parts?
Appreciate any advice, Thanks
Re: Do i need a special Lamdba Sensor?
Post by Martin F »
The standard lambda sensor will be fine, you could just replace the connectors with either one you don't use or buy a male/female connector and wire it into the loom, failing that you could try items wanted to see if some one would be willing to cut the connector of a faulty sensor and the connector from the loom :eye:
OKI
Post by OKI »
marty1 wrote:The standard lambda sensor will be fine, you could just replace the connectors with either one you don't use or buy a male/female connector and wire it into the loom, failing that you could try items wanted to see if some one would be willing to cut the connector of a faulty sensor and the connector from the loom :eye:
Thanks for advice bud.
What do you mean replace with either one i don't use. Am i likely to find unwanted connectors on the loom??
Im happy to wire new connectors into the loom but i didnt know where to start when looking for them. So you say 'male/female connectors' is there anything else i can use to find the correct ones?
I found a few different lamdba sensors online. Most are £50 but i've seen universal ones for £30. Do you know if these work?
Thanks again
Post by Martin F »
I would stick with a genuine toyota sensor, pretty sure there is another connector on the end of the loom, either cat temp or air-con or fan, if not then an electrical store will have a connector for sale, like maplins :-k
http://www.maplin.co.uk/Search.aspx?menuno=84507
second one down, for example.
nigel_bytes
Post by nigel_bytes »
Maybe this kind of connector would be more suitable,
http://cgi.ebay.co.uk/4-Way-Automotive- ... 4a9bacdb98
Post by Martin F »
nigel_bytes wrote:Maybe this kind of connector would be more suitable,
That would be perfect, good find :clap: :clap:
OKI
Post by OKI »
THANKS GUYS.
I will order the ebay connector today (nice one Nigel).
I guess its a £55 lamdba sensor then and not the cheapo universal one :(
I found this from JustLamdba @ £55 http://www.lambdasensor.com/main/mr2.htm
but i've just noticed it says 'universal type sensor'
Fensport dont stock them, nor do Japarts.. I doubt Toyota main dealer will stock them either, as its an import.
Know any good part suppliers who will stock the geniune part? Lots being sold on ebay but i dont trust that they are geniune.
Thanks again guys (sorry, i know i talk too much)
OKI
Post by OKI »
Just found this one on ebay @ £40, looks identical to mine.
http://cgi.ebay.co.uk/Lambda-Sensor-Toy ... 2770wt_941
BUT....
The part no. & engine no. don't match.. My sensor is 89465-17130 which is not listed and in the car list it doesn't have the 3S-GTE only 3S-GE, years dont match either come to think of it. (pretty pointless link then really)
OKI
Post by OKI »
Whats all this about Front & rear lamdba sensors??
I need the one that fits into the Turbo housing, next to the dipstick. I presume thats the rear sensor?? Lots of front ones online.
toxo
Post by toxo »
Front & rear sensors are for MK3s.
RobCrezz
Post by RobCrezz »
OKI wrote:THANKS GUYS.
I got the 4 wire rev3 one from Justlambda and it works fine.
OKI
Post by OKI »
Good to know. Thanks Rob. I'll contact them today and see about ordering one.
