Update: Had manifold fitted and it had many probs.
All pipework needed refabricating around about.
Chargecooler needed moving out of thw way as the manifold had moved the turbo and wastegate.
Then had warped flanges.
Then once all was done and fitted, it wouldnt flow well.
In meantime my Gt3076r was declared u/s and was replaced with a nice new GT3582r.
On removal of manifold it was found to be cracking already and discoloured where it was restricting flow.
So Manifold wise, i have opted now for a KORacing manifold and am awaiting delivery.
then, touch wood, all will map nicely.
Also had an an aftermarket thermostatically controlled oil cooler and relocation kit fitted.
Not sure what make.
Will keep you posted on results.
