I have a K&N Filter cone and have seen these fitted direct to the T-Vis
Can a K&N Air filter be fitted direct to the T-Vis and what do you have to do with all the smaller tubing???
Is there a write up anywhere??
with thanks
un1eash wrote:Once moving theres plenty of air flow up through the engine bay to not worry about heat soak.
Rossyboy99 wrote:is there anyway to modify a sheild for this to prevent heat soak as thats pretty confined in the engine bay and will suffer from the heat, on other cars i've made stainless sheilds to confine the filter within the bay from as much heat as possible etc.
cartledge_uk wrote:un1eash wrote:Once moving theres plenty of air flow up through the engine bay to not worry about heat soak.
If you don't believe this, undo your engine catch and go for a drive, the force of the air will lift the engine lid open at a high enough speed, I cant remember the speed 50-60mph maybe.
kaiowas wrote:
That just demonstates that there is a high pressure in the engine bay compared to above the deck, doesn't confirm that there is high airflow when the cover is closed at all.
/pedant
superwhite wrote:Your right, it is the pressure difference.However because the vents are there and there is a big pressure difference then lots of air will be being pulled through the vents
= air flow past the filter.
just my 2p's worth.
