Arc intercooler,Mines ecu,standard cat, Departure 2 exhaust, grade 7 plugs, standard HG.
RobCrezz wrote:Have you unplugged the VSV?
djpkins wrote:sounds like it could just be working off actuator pressure only..
djpkins wrote:have you def got the boost control solenoid plumbed in the right way round..
.you need to eliminate the possibility of faulty components.
djpkins wrote:have you disconnected the vsv? your actuator should have 1 blocked pipe and 1 pipe going to the boost control solenoid.
djpkins wrote:my duty cycle has actually dropped to 67% so i assume it has self learned that, to hold 1 bar boost, that's what it needs to be.
could you have a weak spring in your BOV or a leak somewhere maybe??
David21 wrote:IIRC you need to go to the gears menu and set them all to X.![]()
That should do the job.
The AVC-R will only adjust when you change the settings then.
