Thanks for the hint.
As far as I can see with E6
(the 22pin Rev 1 connector which is plugged into the Rev 3 ECU) the following is my understanding:
Pins 1-11 are okay
Pin 12 Circut opening relay is also okay
Loom Pin 13
(B1) now needs to be linked to ECU Pin 12
(B)
(this could be unnecessary as there may be a join in the loom.
Pin 17
(FC) on the widest connector that the ECU has now has to go to Pin 14 on E6 to also operate the circut opening relay.
(Edit: Not sure about this one
- will review in the morning).
With regards to EA-3
(18 pins, engine bay fuse box) most of the pins are okay:
1-13 are fine, as are 16-18.
Rev 1 loom is
expecting pin 14 to provide a signal from the ECU for the A/C clutch.
However the Rev 3 is expecting to receive a signal from the Inlet Air Temp.
Rev 1 loom is using pin 15 to channel a signal from the inlet air temp sensor to the ECU.
However the Rev 3 is expecting nothing.
So the solution is to move pin 15 over to pin 14's position.
The other connector in the fuse box, I haven't just go around to figuring it out, mainly due to a shortage of data.
The wiring diagrams I have are all for turbos and the 94 diagram doesn't have the via routes
(which connectors) for the circuts.
So if someone has the wiring diagrams for the Rev 3 I would be most appreciative of a copy!
