I have a set of BC coilovers to fit and am going to lower the 2 by approximately 40mm.
Any comments would be appreciated.
James
James7 wrote:Hi folks
I have a set of BC coilovers to fit and am going to lower the 2 by approximately 40mm.![]()
I am going to get the front and rear droplinks replaced at the same time.
Am I able to fit OEM drop links or do I need to get adjustable ones??
James![]()
tarmac terrorist wrote:standard length fit fine on BC coil overs mate i have the same
James7 wrote:tarmac terrorist wrote:standard length fit fine on BC coil overs mate i have the same
Remind me what drop you have on the front and rear.![]()
I'm looking for no gap between the tyre and the arch.
Pretty sure you've gone for that look as well.
James![]()
sw20GTS wrote:@Tarmac terrorist
I noticed you have that air scoop on the drivers side.I am thinking of getting one too.
However, where did you get it and also is it easy to install it yourself?
tarmac terrorist wrote:sw20GTS wrote:@Tarmac terrorist
its on the passenger side![]()
ye its easy to fit, remove the original side panel then are two screws on the window spoiler remove them then refit them when the scoop is on
mine came from supra car developments over 9 years ago, think there are afew places that sell them thou
sw20GTS wrote:tarmac terrorist wrote:sw20GTS wrote:@Tarmac terrorist
Sounds like something I can do
Gonna hunt one down then.Does it make any difference to cooling? I get warning light after some enthusiastic driving atm.
Stock engine cooling fans etc.
Leon. wrote:Not sure about BC but with Tein, you can use OEM rears, but will need shorter ones on the front, with 40mm drop.
See my KB article for suitable replacement- stay clear of adjustable links, IMO.
http://www.imoc.co.uk/forums/kb.php?mode=article&k=85
