[Mk2] [Turbo] HELP seems to b one thing after another
wull
Post by wull »
well not long had my tubby now its a mk2 rev 1 turbo and have had a few problems first thing was my rad hose leaking so replaced it and done thermostat at the same time then the rad burst so replaced this but wen i went to bleed the system i noticed water dripping from the drivers side of the engine bay i thot it was just water lying about but wen i took the car a run heater was fine then it went cold so i parked the car up to cool down nd wen i checked the water it was low it didnt take much but wen ran heater was warm again but same thing happened again thers also a gurgling noise wen engine is turned off at operating temp but this noise has bn ther since i got the car does anyone have any ideas any help would be appreciated thanks
Re: [Mk2] [Turbo] HELP seems to b one thing after another
Post by Martin F »
so are you still losing water ?
the gurgling noise happens in many turbos but it sounds that if you haven't got another leak you haven't bleed the system properly.
when i got a coolant change at toyota years ago it took them 3 hours to fill and bleed the system properly, did you spend this time plus more when you did it?
wull
Post by wull »
yes i still have the leak its dripping from drivers side of engine bay and it took me bout 2 hours bleeding it front end raised on a 2 post ramp any ideas bout the water dripping as i dont think tht an air lock would coz the water to keep dropping
Post by Martin F »
wull wrote:yes i still have the leak its dripping from drivers side of engine bay and it took me bout 2 hours bleeding it front end raised on a 2 post ramp any ideas bout the water dripping as i dont think tht an air lock would coz the water to keep dropping
this could be your problem, you need to find out exactly where it is leaking from :-k
tarmac terrorist
Post by tarmac terrorist »
drivers side is it near engine or bulkhead ??could be thermostate housing leaking or clip not strong enough to hold good seal on hose,i removed all my original hose clamps & replaced with jubilee clips doubled up on every hose,if its bulkhead could be the heater pipes leaking?? has it had a clutch replaced ??
Last edited by tarmac terrorist on Sun Aug 23, 2009 12:33 pm, edited 1 time in total.
wull
Post by wull »
i think so too anyone got any ideas as to wer it could b coming from only thing i can think of is waterpump and if it is would i b better doing a head gasket while im doing the waterpump
tarmac terrorist
wull wrote:i think so too anyone got any ideas as to wer it could b coming from only thing i can think of is waterpump and if it is would i b better doing a head gasket while im doing the waterpump
was it leaking before you replaced the thermostate ??
wull
Post by wull »
dont know tbh but thnx for the help ill check them out today or tomorrow and see as all i seen was the water dripping from underneath
